aq251 wont light up
polcat1p
Member Posts: 28
just installed my aq251 and its not lighting up or anything. it has power going to it.
everything is hooked up but my heat t-stats, because they didnt come in yet.
anyone have any ideas what it could be?
thanks
thanks
primary pump
i did a p/s piping , but when there is a dhw call the boiler pump doesnt run. it will run when i do a system purge. is there something i need to do?
thanks0 -
aq
When programming the control, change the dhw device to valve instead of pump. This should fix your problem.0
- 117 Geothermal
