Hot Water recirculating line
Mpj
Member Posts: 109
Can somebody help me out with piping a recirculating line for domestic hot water too four baths, kitchen and laundry. Baths are on all four corners of the house and kitchen /laundry in the rear. I was thinking a tee off each hot water pipe back to a manifold (with valves) and set up a pump on the water heater with a timer or aquatstat. Each bath has its own set of risers (PEX) with isolation valves.
Thanks for the help
Thanks for the help
Recirc.
Yes, you can do it that way. The other way is one big loop with short branches off the main to each bathroom, laundry or kitchen and only one return back to the water heater. It really depends on the layout and access. Draw it out on a piece of paper.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thanks
Thanks foe the reply Allan, sorry I did not respond earlier I was out of town.
I will run the manifold system, it will be a little easier.
Thanks0 -
You might want to consider...
... demand controls, or the piping can lose a lot of heat. I understand that 24 hour recirc can triple one's water heating bill. www.gothotwater.com is the originator of the idea.
Yours, Larry0 -
DHW Recirc
B&G has a very complete and energy effecient solution for your application, Here is a link to there site. Kevin
http://completewatersystems.com/?product=ecocirc-e3-domestic-hot-water-circulators0 -
Hot water
Thanks Kevin,
That looks like what I am looking for.0 -
Very happy with my Grundfos
http://net.grundfos.com/doc/webnet/instantlyhot/languages/en/home/installers-wholesalers/products/comfort/
Very simple yet very sophisticated. Whichever product you use, insulate those pipes!
Good luck,
Patrick0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
