Leaking Dunkirk boiler
charlie1200
Member Posts: 5
I've got Dunkirk Oil-fired steam boiler that was installed in the fall of 03. The model # is 3es1.ooc manufactured on !/9/03. I was using up water and couldnt see where it was leaking from,[single pipe-no underground return lines] so I decided to fill the system with water and come to find out the boiler is leaking up towards the top,took off the exhaust pipe and top cover], I can see where its leaking,its down a couple of inches but between 2 sections. Would the boiler alone be covered in warranty? The installing co. never left the owners manual or warranty!! Can I find this stuff online? Can the boiler be welded?I'd hate to have another boiler installed. any suggestions or ideas will be greatly appreciated.
Look here
I don't see your boiler listed, see if any of these numbers make sense.
http://www.dunkirk.com/product_literature.asp
You might try contacting customer service to wee if they can help you.
3PSI gauge0 -
It's probably the older Empire Steam model
I have an old brochure showing it. 3-section, no tankless coil, 371 square feet EDR. It looks a lot like an older Utica Starfire II. These units had a 12-year warranty. Find a good steam contractor (try Find a Contractor at the top of the page) to handle the warranty arrangements and installation.
Also, look for leaky vents, valve packings and other places where water or steam might escape. Have a Hydrolevel VXT feeder installed with the new boiler, since it has a counter that monitors the amount of water the system takes in. Excessive water intake can kill a boiler.All Steamed Up, Inc.
Consulting0 -
more pics
I'm going to post some more pics of my boiler. Does the piping look alright?0 -
more pics
Nope
the header has a concentric reduction in it. And the return connections don't come down below the waterline before tying together. When it's replaced, figure on having all that re-done. You'll be amazed at how much better it works.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
