hot water pressure
highwyre
Member Posts: 2
in Oil Heating
i have an efm oil boiler. my problem is; i seem to have lost the hot water pressure. it just trickles out. the unit is 25 years old & never had this problem before. what could it be & how can i fix it. it is hard taking a shower, doing wash & running the dishwasher. i NEED help, it's making me crazy!!
I am assuming this is
an oil boiler with a tankless coil. The coil needs changed or acid washed most likely. are there any controls to limit water temperature such as a mixing valve? These may be clogged too. Try the find a contractor at the top of the page.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 120 Geothermal
