multiple light commercial boilers
benthere
Member Posts: 1
I have been asked to quote to install 3 oil steam boilers to replace an older single unit for the purposes of zoning and reserve heat in our 1912 village hall. What would be piping arrangements using a common return, ( condensate reciever/pump ).
What brand of boiler are you looking at using
if you are zoning with the boilers then I would separate the returns too.Cost is what you spend , value is what you get.
cell # 413-841-6726
Have you already done
a survey of your radiation? It may be the new boiler will be far smaller than they expect it to be.Cost is what you spend , value is what you get.
cell # 413-841-6726
zoning a steam boiler
one way that could be done with one boiler, would be with the steam section handling the main area, and a hot-water loop off the boiler handling the less used area, properly controlled.
usually this sort of steam-zoning plan is hatched as a result of high fuel bills--not as a result of steam being so inefficient, but because of lack of maintenance making the system burn more fuel. zoning a steam system has some hurdles to overcome.
if this steam system is properly surveyed for edr, and condition, and corrected, i imagine the bills will be less.--nbc0
- 120 Geothermal
