Burnham Plug and play
Hauss
Member Posts: 2
Just wired my outdoor reset for my new Burnham MPO. I have an indirect DHWH. Does anyone no whether or not I have to adjust the boiler temp now to the same setting as my hot water indirect (135 deg.)? I now it's plug and play but I feel the limit settings should be adjusted. Doesn't seem to be a whole lot known about them in my area.
Plug and play
Its just that...plug and play. As long as your aquastat for your DHWH it tied in correctly (terminals 3-4 on the outdoor reset card), that will bypass the ODR on a dhw call.0 -
plug and play
im looking into this boiler as a replacement for my old war horse downstairs.how is it going for you and would you recomend it.any chance of a pic of the installation0 -
The MPO
should be on your short list. It's one of the better oil-fired boilers available today.All Steamed Up, Inc.
Consulting0 -
plug and play
sorry i got them mixed up ,i was looking at the es2 gas fired.would you still recomend that or the pvg model which the gas company is giving a good deal on,thanks.sorry going of topic here0 -
Depends
the PVG is a power-vented unit. Are you planning to vent thru an existing re-lined chimney? If so, I'd go with the ES-2.All Steamed Up, Inc.
Consulting0 -
Or wait
The sidewall vented boiler with the IQ control system like the ES2 and MPO-IQ will be out shortly. It will be powervented or direct vented take your pick.0 -
plug and play
do you know when they are coming out.is it before the next heating season?0 -
ESC - nSidewall vented boiler with IQ system.
I have heard the second or third quarter of this year.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
