piping of a coil?
jonny88
Member Posts: 1,139
what is the reason for a 24" loop before the cold water line goes into the coil or the holby mixing valve.thanks
to stop
thermal migration.gwgillplumbingandheating.com
24"
why is it not necesssary to pipe a water heater this way0 -
they used
to do it on water heaters. Years ago.gwgillplumbingandheating.com
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
