looking for tankless heater gasket
climbey
Member Posts: 6
in Oil Heating
I am trying to find a new tankless heater gasket for a Burnham boiler model RS-110. If anyone knows the part number for this and also the heater coil and cover plate and where they could be purchased it would be greatly appreciated. Thank you.
gasket
Are you looking for just a gasket, or a new tankless coil? The gasket comes with a new coil. They can be had through a supply house, I think only. I prefer Everhot, but I think Triangle Tube also makes them. The part #'s i have would be Sid Harvey's if needed, and if you deal with them. I don't use gaskets, we use teflon Redi-Rope. Only way to go.0 -
gasket
I would appreciate the part numbers for either the gasket or the hot water coil for the Burnham RS110.Thank you.0 -
tankless coil
TF/Everhot part# RSM-50 -
gasket
Anyone know of any supply stores online where this part can be ordered. Thank you.0
