Water heater problem
Wayco Wayne_2
Member Posts: 2,479
I just helped out a neighbor by replacing their water heater that started leaking. Not a big deal. Just a 50 gallon nat gas with draft diverter at the top. Connect cold pipe to cold pipe. Hot to hot. Run new flu pipe. I even added an expansion tank. What could be more simple? Now a week later they are saying they are experiencing hot water coming out of the cold water spigot s for a short while. I went in to the kitchen sink and turned on the cold water after running about 10 seconds, sure enough, about 10 seconds of hot water followed by cold. What the heck! What could be happening?
Pressure drop
The domestic water pressure is probably falling when water is released, causing the contents of the expansion tank to backflow through the water heater and back up the cold water inlet. You could install a check valve in the cold feed to the water heater to stop this.0 -
could .................
the dip tube have been damaged or dislodged ?0 -
expansion tank
It's the expansion tank as Tom said. Curious where you installed the tank and on which line?0 -
NO GOOD DEED GOES UNPUNISHED
The problem is due to the expansion tank. You were Mr. nice and added an expansion tank. Was it necessary? Were there expansion problems? If the old heater functioned without an expansion tank without the T&P valve relieving or dripping, I would go back and remove the tank and plug the connection.
Don't you hate being the good guy and being bitten on the butt?0 -
I don't
Think it needed an expansion tank. I'll take it off and see if the problem goes away. they say don't help friends and neighbors but I can't help myself. they're such nice folks.0 -
I don't
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
