Heat Pump Water Heater in Mechanical Room
I have a project with significant waste heat in a very large mechanical room. I would like to reclaim the heat and am considering a HP water heater for domestics as an option. Are there any systems out there with ducted exhaust?
  • Brad White
    Brad White Member Posts: 2,399
    Is the waste heat in the air?
    If it is a warm and even humid room otherwise, there is a product, name escapes me. This device is an AC unit/dehumidifier which sits atop the DHW heater and uses the hot gas waste heat from the refrigerant process to pre-heat the DHW incoming cold water. (Rather uses the incoming CW as a water-cooled condensing medium).
    If I come across the name I will post it but others I am sure know the one I am talking about.
    There also were a line of Free-heaters from Spiro (the spirovent people) and Meuller refrigeration specialties, to take the same hot gas waste heat from commercial refrigeration and use it also to pre-heat incoming CW to DHW systems. We specify the Meuller line on commercial kitchens but I see no reason it cannot be adapted to other AC processes.
    Depending on how hot the room is, a more passive coil situation could be used, but the refrigerant boost is more positive.
    How hot IS this room?  It may be as hot as my grandfather used to say: "Hot as a June Bride in a Feather-Bed". Now that, my friend, is hot. :)
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • Steve_210
    Steve_210 Member Posts: 664
    A O smith
    Make a unit like what brad mentioned. Just seen it at a show
  • TMorg
    TMorg Member Posts: 23
    HP water heater
    Rheem/ Ruud makes a really nice unit.
    Steamhead Member Posts: 18,497
    I think
    it's called a "desuperheater".
    Consulting
