Kitchen remodel and baseboard convectors
GordoG
Member Posts: 15
<span style="font-size:12pt">We are planning a kitchen remodel/upgrade that will include new cabinets, electrical outlets, lights, hardwood floor and wall paint. That leaves the baseboard convectors are probably 60 years old. They are 'L' shaped and are 9' and 5' long. Convectors are 9.5" tall and 3" deep.</span>
<span style="font-size:12pt">Option 1: Remove the metal covers, have the paint stripped and powder coat them at a local shop.</span>
<span style="font-size:12pt">Option 2: Replace the the convectors with new ones. My system is a series loop (1 1/4" steel pipe) that splits in two with each sub loop ( 1" steel pipe) circling around half the 1St floor and meeting again before returning (1 1/4" steel pipe) to the boiler. There is about 12' of steel fins on the convectors in the kitchen. Would new convectors have to be 1" pipe also? Would 3/4" pipe create too much resistance?</span>
<span style="font-size:12pt">I have a heating service company who knows hydronic systems, but I don't want to get snookered by a sales person. I would appreciate any ideas, hints or advice. Thanks. </span>
You want to keep them the same size
unless you want to redo the whole system. You may be able to use 1" copper. Is this hot water or steam? If it is steam stay with 1" iron if that is what is there. You could cause balance issues. This is with out benefit of photos or seeing it in person. This is the safe answer.Cost is what you spend , value is what you get.
cell # 413-841-6726
System type
It is a hot water system. Some of the pipes in the basement have been painted silver so I do not know if they are galvanized pipe or black pipe. They are all threaded though. The system works good now so I do not want to upset the balance of it. Thanks.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
