TigerLoop Fitting Kit
timo888
Member Posts: 137
in Oil Heating
When I search
<a href="http://www.lmgtfy.com/?q=%2BTigerLoop+%2BFitting+%2BKit">http://www.lmgtfy.com/?q=%2BTigerLoop+%2BFitting+%2BKit</a>
the results all come back for the United Kingdom -- aren't there any hose and fitting kits for the TigerLoop sold as a package here in the US?
The TL has 1/4" connections -- in the US are 3/8" flexible lines usually used rather than 1/4"? Do people normally put 1/4 to 3/8 adapters into the TigerLoop?
tiger loop
I generally use 1/4M x 3/8 flared 90s and flex connectors with flare female swivels...great fit. Just installed a Tiger loop Ultra...nice rig but the inlet has a 3/8 firomatic........0 -
I agree about
the Tigerloop Ultra . Tigerloop and spin on filter all in one . But I don't think the Ultra comes with flex lines .
I've only seen 1/4 inch flex lines , which is just fine for the short distance between the TL and burner . I haven't seen a kit that comes with all the flex lines and fittings to adapt to each burner . The flex lines we get are adapted to 1/4 inch threads already , so connecting the lines between the TL and Riello are a snap . That is , if the installer left the bypass plug , pump return pipe and adapter for the Riello . You'd just need fittings to connect the filter to the TL .0
- 120 Geothermal
