Good Steam Plumber in Boston area
Can anybody recommend a steam knowledgeable plumber in the Boston area? We have a old commercial style Paul steam system in our house and it has issues like water hammer, losing water, and huge heating bills. I am considering changing it over to forced hot water since I would like to keep some of the old empire style radiators.
Thanks
    Steamhead Member Posts: 18,508
    edited April 2011
    Try Ed Wallace
    not sure of his phone number but he knows steam.
    I wouldn't even think about converting that system. It's likely the radiators are a type that would not work with hot water. Also, hot-water needs at least ten times the pressure of steam, which can cause leaks, and even if the radiators were capable of working with water they might not be big enough to heat the building.
    Keep the Paul system. It's fixable.
    Consulting
  • ed wallace
    ed wallace Member Posts: 1,612
    edited April 2011
    hi frank thank you for the vote of confidence I would be happy to look at his system
  • Stephen Hickey
    Stephen Hickey Member Posts: 4
    thanks for referral
    Thanks for the referral. Ed, can you send me your number? Mine in 617-666-3134.
    No problem
    but you do need to get a Find a Contractor ad from Dan. That way people can find you without someone from Baltimore having to step in ;-) Believe me, it's worth it!
    BTW, i might be up that way next month. E-mail me your cell # in case I can't find it from earlier, and we'll hook up.
    Consulting
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    No he does not need to get an add
    I have one. I that's enough for the whole state.
    cell # 413-841-6726
