Recommended Steam Expert Lower Westchester NY?
Hoog23
Member Posts: 19
Hello,
There is nobody listed in my area and one of the recommended contractors in NYC didn't want to head up my way (or maybe he wasn't licensed in my county..).
I have a single pipe steam system that I want to convert from oil to gas. My boiler is original Thatcher with a coil. I have gas service and have been told the main/meter should be large enough and my chimney is clay lined.
Everything actually works pretty well. My basement oil tank is 1938 and I think it is time to either replace it or convert to gas.
Thanks in advance.
Thanks in advance.
You may need to search a bit wider
did you use the zip code search or the state search? I recommend the state search or use at least 100 miles for a radius.Cost is what you spend , value is what you get.
cell # 413-841-6726
http://www.heatinghelp.com/forum-thread/135863/Recommended-Steam-Expert-Lower-Westchester-NY
Hi my name is Chris , I'm from central Jersey.
Send me some shots of your Thatcher and I will let you know if i can replace it for you. We just finished a dinosaur like your in Hillside NJ.
Thanks0
