Searching for steam heat experts in Fairfield County
Clarke
Member Posts: 3
I own an old building in Norwalk Ct. It has steam heat and the boiler is on its last legs. I appreciate the art of steam heat systems. Looking for steam heat experts (individuals or companies) in Fairfield county to help me get replacement boiler installed. Having difficulty finding contractor in Fairfield County that really knows his stuff and that I can rely on for expert reliable steam boiler installation. Do you know any individuals or companies in Fairfield County that you would consider steam heat experts?? Any help appreciated.
Only one I know of
in CT is Scott Kneeland. He's listed on the Find a Contractor page, go here:
http://www.heatinghelp.com/professional/51/Scotland-Heating-A-CAll Steamed Up, Inc.
Consulting0 -
At the risk of excluding
any of the many fine steam practitioners in the greater NYC area (yes, I know, you are your own, but just for proximity), there is Triple Crown P&H, Gateway, TGO, in and around NY and on LI. In CT there is also Bob Bona, but I do not have his contact info at hand. There are others and the risk of leaving them out is ever-present.
Yes, Paul Fredricks too!"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Is this gas or oil fired?0 -
Steam heat experts in CT
Gas fired0 -
Steam experts in Ffld Cnty
Contact Joseph M. Flaherty Co. in Darien. I think the number 655-07240
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
