Radiant thermostats using floor sensors?
Glenn Harrison_2
Member Posts: 845
Looking for opinions from you guys that install them all the time.
I am working on a job that has 8 floor warming zones on four different floors (basement plus 3) The building is set up to have all thermostats located in one room, and remote floor sensors installed for each zone. We want to use as simple as possible thermostats, but obviously quality and reliability in a radiant floor is needed. Just curious to see what others are using for floor temp control, that can remote sense the floor temperature.
TIA
TIA
AQ1000
I'm just a homeowner, but I know that the Honeywell AQ1000 will do that. I've got those stats with my system (non radiant) and I'm really happy with them. The floor sensor connects to the stat and the stat is two wire back to the panel. Outdoor temp is nice to have at each stat too.0 -
floor sensing stats
One word answer....TEKMAR0 -
Al is dead on.
Tekmar all the way. Many options to control as needed.0 -
Wirsbo 511s
Programable and allow for either just floor sensing, air sensing or a combination of both. Also learns the cycles of the room.There was an error rendering this rich post.
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
