ICF forms (Rastra blocks) & slab edge insulation
DJFiler
DJFiler Member Posts: 1
how suitable are Rastra Insulated concrete forms for slab edge insulation in a radiant floor job-  if the radiant slab is poured right up against the Rastra blocks without an additional thermal break, how serious is the slab edge heat loss into the Rastra blocks?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    You'll be fine...
    Rastra block has decent R value. Most slabs get NO thermal break, and they work fine, although not the most efficient use of energy tho...
    ME
