plumbing mechanic
plumber
Member Posts: 1
Why can't you use mallable fittings on a steam boiler?
Malleble Fittings vs Cast
You can use mallable fittings however if you wish to ever get them apart, cracking a cast fitting makes it much easier. Pressure isn't a problem as residential steam systems operate at under 2 PSI,
- Rod0
- 167 Indoor-Air Quality
