bacharach analyser..
Muru
Member Posts: 2
in Gas Heating
any ony have used bacharach fyrite pro 125 flue gas analyser? How long O2 sensor life coming? what other problems being faced in the instrument?. I am going to buy old unused instrument.is it worth buying this?
Fyrerite Pro:
Although it is an unused instrument, you don't get any warranties with it. Newer combustion instruments have field replacable sensors. The old Fyrerites fif not. You must send it back to have it updated and calibrated. A lot have switched to Testo and Wohler because you can change the sensors. If you are planning to only do a few tests, you may find that when you want to use it, the sensor isn't working because they have a limit of how mwny tests they can do and how long they are good for.
A old model may seem like a good deal but it may turn out to be not that good in the field.0
