Steam Controls
davanPa
Member Posts: 2
We bought our first house and it has gas steam boiler. Sometimes I have to knock on a grey "honeywell" box attached to a curved small pipe on the side of the boiler to get the boiler to fire when it is calling for heat. What does that thing do and what is that big black "T" below it do? Are they some type of controls ?
That box is the Pressuretrol
Does it have a curly pipe under it? That may be clogged.Cost is what you spend , value is what you get.
cell # 413-841-6726
The tee is the low water cut off
It protects the boiler from dry firing. It needs drained (blown down) once a week. The box controls the pressure your system reaches. Lower is better on that. If that curly pipe is clogged it can not read the pressure in the boiler so it ends up wasting your heating dollars big time while over stressing your air vents and valves on the rest of your system again costing you money. The book "Got Steam" s a good place to start learning in more detail about your system with out getting overly technical yet informative enough to be well worth the investment.Cost is what you spend , value is what you get.
cell # 413-841-6726
reply
Yes it has that pipe and I believe it was changed last year. What does it do and what is the black thing it is attached to do.0
- 167 Indoor-Air Quality
