richmond radiators
STEAM DOCTOR
Member Posts: 2,414
I just finished taking a radiator survey in my home. I plan on replacing my gas fired steam boiler after the heating season is done. I have 3 Richmond radiators. I didn't see them listed in Dan's EDR book. Does anyone have any info on them? They are steam only rads, column type. If i cant get specific info I will go with the generic edr for colum rads listed in Lost Art. Thanks
They should be standard column rads
so any of the usual column charts should work. But if you're not sure, post some pictures so we can see them.All Steamed Up, Inc.
Consulting0 -
Thanks
They are standard column(at least to the naked eye). They are all 3 or 2 column and I assessed them at 40 ft edr.0 -
RICHMOND RADIATORS
POST THE HEIGHTFROM THE FLOOR, NUMBER OF COLUMNS PER CELL AND NUMBER OF CELLS AND I CAN GIVE YOU THE EDR. I HAVE A RICHMOND CATALOGUE.0 -
RICHMOND RADIATORS
Go to Resources at the top of the page, then radiators. There's a section on Richmond Radiators which contains all of the EDR information. I forgot I had sent the pamphlet to Dan for posting.0 -
Thanks
I just took a look in library. The ratings are just about identical to standard column radiator ratings.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
