richmond radiators
I just finished taking a radiator survey in my home. I plan on replacing my gas fired steam boiler after the heating season is done. I have 3 Richmond radiators. I didn't see them listed in Dan's EDR book. Does anyone have any info on them? They are steam only rads, column type. If i cant get specific info I will go with the generic edr for colum rads listed in Lost Art. Thanks
    Steamhead Member Posts: 18,176
    They should be standard column rads
    so any of the usual column charts should work. But if you're not sure, post some pictures so we can see them.
    Consulting
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,502
    edited February 2011
    Thanks
    They are standard column(at least to the naked eye). They are all 3 or 2 column and I assessed them at 40 ft edr.
  • BRIANJ
    BRIANJ Member Posts: 118
    RICHMOND RADIATORS
    POST THE HEIGHTFROM THE FLOOR, NUMBER OF COLUMNS PER CELL AND NUMBER OF CELLS AND I CAN GIVE YOU THE EDR.  I HAVE A RICHMOND CATALOGUE.
  • BRIANJ
    RICHMOND RADIATORS
    Go to Resources at the top of the page, then radiators. There's a section on Richmond Radiators which contains all of the EDR information. I forgot  I had sent the pamphlet to Dan for posting.
  • STEAM DOCTOR
    Thanks
    I just took a look in library. The ratings are just about identical to standard column radiator ratings.
