How do you submit a scanned book to the resources?
moneypitfeeder
Member Posts: 249
Hello, I have 1908 copy of Practical Steam and Hot Water Heating and Ventilation by Alfred King, and a 1916 set of the Cyclopedia of Architecture, Carpentry, & Building, that I'd be willing to scan and upload to this site (if anyone is interested) The "cyclopedia" as its spelled I would only upload heating related info as it contains many volumes. Is there a link that I can send this info to?
Thanks All!
Thanks All!
Scanning
Try contacting Dan H. to steer you in the right direction0 -
When I do this
I scan to at least 600 DPI and save it as a PDF- this gives good resolution and keeps the file size down. The latter is important since, believe it or not, there are some of us who can only get dial-up Internet access.All Steamed Up, Inc.
Consulting0 -
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
1909 Cyclopedia ...
The steam volume is here:
Cyclopedia of Architecture, Carpentry and Building: Heating and ventilation. Steam and hot-water fitting. Plumbing .. http://books.google.com/books?id=NGc1AAAAMAAJ
Notice this is 1909 .. the original poster mentioned 1916 version .. there are several other 1909 volumes available as well at Google Books1-pipe Homeowner - Queens, NYC
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
