Steam radiator rating
Does anyone have an information on the output of the radiator in the attached photos?
These are two-pipe steam radiators installed in 1904.  The name on the top cover is GILLIS & GEO CHEGAN NY.  The name on the base is AA CRIFPING IRON CO  NY.
Jeff Eichenwald
  • Tim_75
    Tim_75 Member Posts: 44
    EDR - the book
    There' a fellow here, Dan Holohan, that knows a little about these things and even wrote a book, just for this very reason.E.D.R. - Ratings for Every Darn Radiator (and convector) you'll probably ever see
  • moneypitfeeder
    moneypitfeeder Member Posts: 252
    misspelled?
    Are you sure the name on the rad isn't A. A. Griffing Iron Co.?
  • moneypitfeeder
    looks kinda like
    The bundy made by AA Griffing, check the link below on the right side of the page there's a link for read online. You'll have to measure it and look on the chart to find the radiation.
    http://openlibrary.org/works/OL7907502W/Bundy_radiators_for_steam_and_hot_water
    Hope it helps
  • BobC
    BobC Member Posts: 5,539
    edited February 2011
    good enough
    This is how I figure out the EDR of a radiator when i don't have tables available, it's not 100% accurate but good enough.
    Wrap a piece of string around that end tube so you can measure the outside diameter of the tube and then figure out how long all those tubes are. Multiply the total length of the tube by the diameter and that will give you the area of the radiant surface, divide that number by 144 and that will give you the EDR in sq feet.
    Bob
    3PSI gauge
  • crash2009
    crash2009 Member Posts: 1,478
    Here is the link
     to the "Bundy Radiator" up in the library here. Griffing Iron Company   http://www.heatinghelp.com/files/articles/1275/92.pdf
