more that one main vent
Natasha
How to add more than one Gordon main vent. What is the name of the splitter-pipe? Where to purchase it?
antler or menorah
these are made up of "tees" and elbows, nipples etc, from the hardware store. maybe someone can add a good picture to this thread.--nbc
found one:
http://www.heatinghelp.com/forum-thread/127856/Main-Vent-Installation0 -
Antler arrangment
Where to get the pipe to antler arrange the gorton #1 main vents? (see attached)0 -
Vent Capacity
If you need more than 2 Gorton #1's then you should get the Gorton #2
It has three times the vent capacity of the #1 and will cost you a bit less than three of the #1's
What diameter and how long are you main's?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
