Anyone using nordfab for oil exahust pipe?
cwilliams2000
Member Posts: 140
My ductwork is in bad shape, and I want to replace it, and the nordfab claims that it is 100 percent seamless and certainless seems to be the best piping around. They rate it at up to 600* which should be adequate. Is anyone using their piping off your boiler installs? thank you
Nordfab
I don’t know the answer, but Nordfab’s customer service line is 1-800-532-0830 and they were very helpful when I had a question, so you may want to call them directly if no one else knows0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
