Condensate
FireGuy
Member Posts: 1
I have a two boiler steam System, with a large condensate return tank! I am having trouble with the return tank overflowing on a daily basis. When i check the boiler the level is about half to 3/4 and then later the floor is wet!! My condensate return is running 110 to 119 for temp. I have checked traps for proper function and i have come up with nothing!! Please help!!!
Surge Tank? And some questions.
How long has this been happening and if it worked recently, what might have changed to make it different?
How large is the system?
Is the source of the water on the floor from the boilers too or just the tank overflowing?
"Normally" (a highly qualified term), a large distribution system would have a surge tank, sufficient to hold 20 minutes of condensate during, most often, a cold start-up. Your colder condensate points to a larger system and prolonged warm-up, or a preponderance of outside air heating coils or other cold processes. What does this serve?
How large are the boilers (in PPH, EDR, BTUH for example) and the tank (in gallons)?
Is the water make-up made directly to the boilers or to this tank?
If the condensate return is delayed for whatever reason, tank make-up will start and when the return finally comes, dial 1-800-NoahArk.
When the flooding happens in the cycle is key information.
Is this tank in fact a surge tank by itself or is it also the boiler feed tank? (Anything between this tank, it's pumps and the boilers?)
How are the controls set up? If it is boiler feed, the boiler water level controller rules. If it is set up or mis-controlled as a condensate receiver, it empties when it has to pee basically, regardless of boiler needs.
A bit for you to chew on, but there are holes I need to fill to help if I can. Others may well have better questions, I am sure.
Brad"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
