pex minimum flow
crawler
Member Posts: 1
What is the min. flow rate for 1/2" pex tubing in a radiant floor installation?
Zero
when the pump is off."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
What's the most efficiency boiler?
exactly Brad....There was an error rendering this rich post.
Go here...
Interesting discussion from a few years back.
http://radnet.groupee.net/eve/forums/a/tpc/f/1041029701/m/7761023801
ME0 -
heh
we used to design for so much higher flow rates than these days, hehe...Rob Brown
in beautiful Rockport Maine.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
