water pressure
Smiley
Member Posts: 6
Hopefully this is the right place for this question. I'm looking at installing a Simar in line booster pump on my existing well water system. I'm an hvac contractor but never had to do anything with water pressure except PRV's on boilers. Anyone had any experience with these? good, bad indifferent? Thanks.
pressure
look at adding a grundfos MQ 3-45 1HP ADDS 65 PSI or Mq3-35 3/4hp ADDS 45 PSI MUST HAVE LESS THAN 30 PSI GOING INTO GRUNDFOS PUMP. LOOK IT UP UNDER GRUNDFOS USA0 -
PRESSURE
PUT THIS INTO GOOGEL ......... L-MQ-TL-001 ............ IF YOU CAN NOT BUY ONE OF THESE WHERE YOU LIVE I CAN SELL YOU ONE. EMAIL ME AT eckrobert@rcn.com have a great day0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
