using a mobile trailer to heat 3 buildings
jimbo123
Member Posts: 3
This is simply a what if scenario that I am curious about. Let's three buildings that are served by one 90 hp boiler needs to be replaced can a 100 hp boiler in a mobile trailer serve the needs of all three buildings with only a 2 inch hose. And if so what kind of pressure should that boiler run at.
temporary heating, "trailer style"
could these buildings even connect to a ground level temporary steam boiler?
i would think that the new supply would have to be cut in above the level of the boiler, and what about the condensate?
is this question a result of some boiler problem?--nbc0
