nozzles
tekmar
Member Posts: 8
in Oil Heating
having a hard time getting hago nozzle .50x60 ss nozzle how come ,is there a web site ,went to two supply houses not in stock thanks
Hago Nozzles:
It's my understanding that Hago nozzles were bought out by Monarch or Danfoss. If you want Hago nozzles, I am told that they are available but you must special order 192 (16 dozen) nozzles of the same size.
I would suggest that if you have an application that the manufacturer is recommending a Hago nozzle for your application, you contact them for assistance in what they recommend in their burner. Most of Carlin and Becketts suggest Delavans.0 -
Same here
so no one carries Hago anymore. Or Danfoss, since they're now the same company.
You can get Delavans thru R.E. Michel, or Delavans and Monarchs thru Sid Harvey.All Steamed Up, Inc.
Consulting0 -
Nozzles:
Steam,
All nozzle brands are not the same.
I strongly suggest contacting the burner manufacturer for what they recommend when they were spec'ing Hago's. The cost of a phone call is cheaper than a free service call.0 -
Sid
Sid still carries Hago.0 -
Only what they already had World.
Due to the quantity requirements, Sids is only selling what they already had in stock.
They will order it but you are responsible for the quantity. Ice is right. I have had to go to the burner manufacturers twice now for nozzle support. There are a handful of burners out there that don't burn worth a crap with anything but a Hago in it.0 -
Not what they told me
I was at the distribution center today they told me they could get me what ever I wanted.0
- 167 Indoor-Air Quality
