small leak on header joint
bosshog277
Member Posts: 1
I am a home owner with a 5 year old Burnam steam boiler. I just noticed a small leak at a joint on the header. (The connection is on that uses a really big wrench) Is there any thing I can put on the joint to stop the leak or do I just need to call the pro?
Thank you
Thank you
Pro
Unless you have a really big wrench and the knowhow to use it, it's time to call a pro.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 110 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
