adding condensate unit
vapor
Member Posts: 1
WOULD LIKE TO ADD A CONDENSATE PUMP TO A 2-PIPE SYSTEM
WITH OLD BURIED RETURNS SERVING 60% OF THE HOUSE.HOW WILL
THIS EFFECT A SECOND RETURN FROM THE OTHER END OF THE HOUSE
WHICH IS STILL GRAVITY?CAN IT BE DONE?.
Why
do you want to add the pump? Do you need to reroute the returns?All Steamed Up, Inc.
Consulting0
