3 1/2" pipe
bovide_4
Member Posts: 161
Anyone know where to buy 3 1/2" pipe and fittings? I encounter this at least twice a year now.
3 1/2 inch Pipe
Hi- Tell us where you are located and perhaps someone reading this knows of a source near you. Another possibility would be to contact Anvil Pipe
http://www.anvilintl.com/Product/PipeFittings.aspx
and they can steer you to a distributor close to you.
- Rod0 -
3 1/2" pipe
I'm in the New York City area. Thanks.0 -
Come to Davenport, Iowa
Hemphill Pipe in Davenport, Iowa keeps it in stock, along with a wide range of fittings.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
great
Thanks a lot. Now the groaning can stop whenever my guys say "it's not 3", and it's not 4". This time I think I will weld a 3 1/2" long radius elbow which Weldbend makes, to replace the leaking threads at the 3 1/2" steam ell. . I would love to go to Iowa, center of American Wrestling. Isn't that where Miletich Fighting systems is located?0 -
Newton
There is a Wrestling Museum in Newton, IA. Newton was also the home of Maytag, until they were bought out by Whirlpool a few years ago, and they closed down all of the original office and factory.Dave in Quad Cities, America
over in the Brooklyn
There's a large place over in Brooklyn. I thought I had it in my cell phone, but I can't find it. I'm pretty sure it has Lyons in the name. They have a 12 story build and a big yard all kinds of pipe.They were shipping out by the trailer load.
We came off of Northern Boulevard over the bridge then off to the left and off to the left down in there.0 -
Fittings
Washington Supply in the Bronx or Quensell Supply in Brooklyn.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
