3 1/2" pipe
bovide_4
bovide_4 Member Posts: 161
Anyone know where to buy 3 1/2" pipe and fittings? I encounter this at least twice a year now.
  • Rod
    Rod Posts: 2,067
    3 1/2 inch Pipe
    Hi- Tell us where you are located and perhaps someone reading this knows of a source near you. Another possibility would be to contact Anvil Pipe
    http://www.anvilintl.com/Product/PipeFittings.aspx
    and they can steer you to a distributor close to you.
    - Rod
  • bovide_4
    3 1/2" pipe
    I'm in the New York City area. Thanks.
  • Dave in QCA
    Dave in QCA Member Posts: 1,804
    edited January 2011
    Come to Davenport, Iowa
    Hemphill Pipe in Davenport, Iowa keeps it in stock, along with a wide range of fittings.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • bovide_4
    great
    Thanks a lot. Now the groaning can stop whenever my guys say "it's not 3", and it's not 4". This time I think I will weld a 3 1/2" long radius elbow which Weldbend makes, to replace the leaking threads at the 3 1/2" steam ell. . I would love to go to Iowa, center of American Wrestling. Isn't that where Miletich Fighting systems is located?
  • Dave in QCA
    edited January 2011
    Newton
    There is a Wrestling Museum in Newton, IA.  Newton was also the home of Maytag, until they were bought out by Whirlpool a few years ago, and they closed down all of the original office and factory.
  • World Plumber
    World Plumber Member Posts: 389
    over in the Brooklyn
    There's a large place over in Brooklyn. I thought I had it in my cell phone, but I can't find it. I'm pretty sure it has Lyons in the name. They have a 12 story build and a big yard all kinds of pipe.They were shipping out by the trailer load.
        We came off of Northern Boulevard over the bridge then off to the left and off to the left down in there.
  • c.t.kay
    c.t.kay Member Posts: 85
    Fittings
    Washington Supply in the Bronx or Quensell Supply in Brooklyn.
