Old steam systems using condensate as HW
Luke_5
Member Posts: 7
<span style="font-size:12pt">I have a 2 story old townhouse with steam piping-2 pipe system. The radiators are all cast iron hot water type. The existing steam riser is basically a pipe within a pipe. Through the inside pipe, steam is flowing and through the outer pipe condensate. The radiators are hot water type and connected to the outer pipe to get condensate. I would like to learn more about this system, does anybody knows how it works or where can I get more info about it.</span>
<span style="font-size:12pt">Thank you</span>
That's a new one on me
how about some pics?All Steamed Up, Inc.
Consulting0 -
Are Your Valves and Traps
Webster? This may be a Webster Innter-Tube (sic) Heating Riser (Patented).All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Some pictures and more details
Not all the pipes are exposed but the steam distribution appears to be like this. One dedicated steam riser in the back of tho house is going up into the attic. In the attic is branching off into two riser, one located in front of the house and the second in the back. All front radiators are connected to the front riser and same for the rear ones.0 -
Sure it's not
a down-feed hot-water system?All Steamed Up, Inc.
Consulting0 -
Pipe "within" a pipe??
What observations have you made that lead you to believe there is a pipe within another pipe?Dave in Quad Cities, America
http://grandviewdavenport.com0 -
It's not a HW system
The entire system is steam. The townhouse gets steam from a central plant. One or 2 radiators have been replaced by the owner with steam radiators (see attached picture). However they did not connect the new radiators to the risers I was explaining before. They ran direct piping from the basement steam lines and the addition/replacement happened on the 1st floor only.
This system, as old as it is, installed by the dead men as Dan Holohan is saying, is very challenging and facinating. That is why I am asking if anyone have seen something like this before. I will post more information as soon as I will get more. I like the steam systems and always run into things I've never seen before...0 -
I saw it
One radiator was disconnected from the riser and I saw the open hole in the riser.0 -
Interesting
Very interesting! I look forward to more pictures and information.Dave in Quad Cities, America
Thank you Haaljo
The link and info is very good. I believe this is what I have found. I will also come with more details once i have the chance to go back and see the site again.
Thank you for all your help.0 -
I see the trap on that radiator
but the other ones don't appear to have traps on them. Maybe the orifice in the riser took care of that?All Steamed Up, Inc.
Consulting0
- 116 Geothermal
- 169 Indoor-Air Quality
