Any networked thermostats that offer web control?
cwilliams2000
Member Posts: 140
Hi I am looking for digital thermostats that hopefully can only use two wires and can be wired in the boiler room and tied into ethernet wirh a web interface and programming. I would like to be able to program them all from one place or centrally turn them up or down? Any ideas, I need 8 therms and am afaraid this will cost a fortune but hope I am wrong. thank you
chris
chris
Tekmar TN2
We've done a few and as far as web interfaces go, it is a good place to start as it is a bit easier to install than others.0 -
There is the Uponor CCN, unfortunantly that will indeed cost a small fortune.0 -
Some Options
http://www.diycontrols.com/c-204-internet-thermostats.aspx?gclid=CJ_p5qeAtqYCFc9w5Qod9UA2Ig&
http://www.gizmag.com/honeywell-prestige-hd-thermostat/11815/
http://news.cnet.com/8301-11128_3-20009937-54.html?tag=contentMain;contentBody;1n
http://www.smarthome.com/3053/IP-Thermostat-Power-Adapter/p.aspx0 -
I use a
x-300 http://www.controlbyweb.com/x300/
The remote sensors are DS18B20 1-wire tech. Alot of features and you can do some "basic" programming to make it do what you need to do.
I have one running a steam system for a 5 family.0 -
Honeywell IAQ
The system runs on three wires but they do it all , Raise - lower and view room temperature on each zone , Adjust humidity settings and view outdoor temperature right on your smart phone or office computer .. Digital and touch screen room thermostats .. Home run or daisy loop the controls ...There was an error rendering this rich post.
- 50 Industry Classes
