New fire tube Knight
aemeeich
Member Posts: 16
So does anyone know when the new fire tube Knight will be available? It is supposed to be sometime in January and I'm really looking forward to using the new design.
new boiler
Lochinvar new heat echanger looks like a Triangle Tube heat echanger anyone know the difference in these boilers? Anyone from Lochinvar have info on the difference that they can email me. Thanks Bob0 -
Exactly the same.
I noticed that too Bob, so I asked around. They are identical. Same manufacturer.0 -
Type of S/S
So Lochinvar is using 439 Stainless steel as well on their new fire tube exchanger?There was an error rendering this rich post.
Re: new wall mount
The heat x is being built by same co. w/ some mods. They are welding the tubes in hxr rather than expanded ends for sealing to heads. I think a different stainless. Coming with Lochinvars control w/ 3 temp control. I think will be real nice. Tim0
