Expansion Tank
CH4
Member Posts: 1
Replaced model #15 extrol tank with a 109 filtrol tank only, system has a pressure reducing valve, did not install filtrol valve because it had pressure reducing valve. Will this system operate properly?
It will work, but if they are like
Amtrol Fill-Trols, the threads for the tank are not plentiful due to an "O" seal. Was the #15 too small or not available to you? It would be best to replace the tank with what you need. Fill-Trol types are a package, and shouldn't be mismatched for best results.0
