Has anyone ever seen radiators like these?
Decided to start another thread to share some pictures.
I am looking for some history on these radiators. I am curious of their age, manufacturer, etc? I know one of them has a patent number from 1874 and is roman column style. The other wrought iron tubular types I have never seen before.
I love these radiators. Any one know anything? Just curious.
similar to mine
since my vents are so quiet [or i am deaf], i have an extra gauge mounted, so i can see when it is firing. the house was built in 1885.--nbc0 -
Nice!!
My house was built around 1880 as well. I love the marble top on that one. Is it removable? My wife will be jealous. Have you ever had any of them repainted?
I have noticed most of my older vents are quite loud. I recently replaced one that was stuck with one like yours and it is now nice and quiet. The Maid o Mist #40 works great.0 -
I believe these are Crane radiators
I have 4 of these 2 pipe Crane radiators in my home circa 1842. I also have 5, 1 pipe radiators in the same home. As you can a lot of marble on top and some on the base. I have never seen these radiators refinished. I can imagine a nice powder coat finish would look very nice. These rads are in Dan's book Every Darn Radiator (E D R). Mine heat very well when I have them heated all the way across.Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal0 -
These are good radiators
Nice marble base. I have seen that book in my google searches. I think i'll have to pick it up. Thanks for sharing!0 -
Very Nice!
My experience is that those old Hoffman #40s are about as silent as you can get. Cool set up on the gauge,and those early wrought tube rads are cool. We had some really similar beauties at Terrace Hill, with marble tops, that had been saved of historical accuracy, even though everything had been converted to commercial air handling type set up. Terrace Hill was built in 1867-1869 and the steam heat was original!Dave in Quad Cities, America
http://grandviewdavenport.com0
