Need Help on Modine type
Mad Dog_2
Member Posts: 8,413
Does anyone know of what the best choice for as modine gas fired unit for a Fire house garage...I'm thinking sealed combustion and/or explosion proof unit. Thanks, Mad Dog
garage heater
Not sure why you need explosion proof but I've installed many Modine HOT DAWG heaters in all kinds of garages and they work great. Unless there is a lot of fumes or chemical being used, that would be my choice for a heater.0 -
Thanks Al........
The Hot Dawg maxxes out at 125 K......I need 150 K. Im going with the PTS 150 sealed combustion. Mad Dog0 -
Hot dawgs
Terminology is different in all areas so I'm not sure what you meant by Fire House garage.........you did select a good heater. Modine makes good stuff.
IF explosion proof not needed, we've installed up to 3 Hot Dawgs in a garage. But again cost is always an issue.0
- 167 Indoor-Air Quality
