prof.
29ok
Member Posts: 1
water level in wood-steam boiler drops out of sight while last radiator spits flood onto floor. what blocks return water? pipes seem clear, this problem new
not properly piped.
If returns are clear then the piping is wrong.Cost is what you spend , value is what you get.
cell # 413-841-6726
piping
I second Charlie! If there are no big leaks or any blockages in the returns then it's piped wrong. Is you equalizer and Hartford Loop Piped right and at the right level?0
