hot water zone
paul debany
Member Posts: 5
How can I pipe a hot water zone off the domestic coil on a steam boiler, any help would be great.
Paul
Paul
Piping is easy....
Controlling the steam boiler and keeping it from kicking steam is where it gets tricky.
Are you comfortable working with high voltage electricity, water, carbon monoxide and fire? If not, maybe you should consider hiring the work out. You can do the grunt work for the distribution/emitters and leave the dangers stuff up to licensed pro's...
ME0
- 167 Indoor-Air Quality
