Source for Pipe Insulation
Manny_PGH
Member Posts: 21
I am looking to add some insulation to some "bare" pipes and all the elbows and joints on the main. Can anyone recommend a source?
Searched on the web and found this - does it look ok as a source - seems to have a lot of different options available
<a href="http://www.statesupply.com/maintenance-supplies/pipe-insulation/steam-pipe-insulation?gclid=CJTf8ObYg6YCFUyD5Qod0mEHoQ&p=1">[u][color=#0066cc]http://www.statesupply.com/maintenance-supplies/pipe-insulation/steam-pipe-insulation?gclid=CJTf8ObYg6YCFUyD5Qod0mEHoQ&p=1[/color][/u]</a>
call john manville
http://www.jm.com/default.htm ..ask them for a local distributor for 1"thick fiberglass pipe insulation..local will be cheaper than online...try to stick with at least that thickness...1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
shipping
The killer for online is shipping. The insulation comes as 3 foot lengths and most places consider it oversize even though the weight isn't much.
-Bob0 -
johns manville locator
they have a good source locator on their site http://www.specjm.com/locator/default.asp choose mechanical & pipe1-pipe Homeowner - Queens, NYC
Wholesaler
I used the locator and found a place only 5 miles away. If they do not deal directly with the public I will get them to tell me who I need to go through. Thanks.0 -
Pipe Insulation
You can always try McMaster.com, they have everything0 -
gwgillplumbingandheating.com
online source
I got ours from:
We used Owens Corning, and it makes a heck of a difference in how the system performs. The insulation that is.
-Bob0 -
Thickness
Where I have insulation it is 1" thick. Should I plan to replace that with thicker stuff, since I saw on one of the sites that 2" thick was available?0 -
Air Lock System
Get job on your Air Lock video Gerry, thanks for sharing that0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
