gorgeous victorian rads reasonably priced .. in the UK :-(
jpf321
Member Posts: 1,568
Wow .. I stumbled into this website .. too bad the freight charges from the UK will kill the very reasonable prices for these gorgeous rads .. <a href="http://www.periodhousestore.co.uk/prods/ornate-cast-iron-radiators.html">http://www.periodhousestore.co.uk/prods/ornate-cast-iron-radiators.html</a>
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
I have a couple like this
And I am closer than the UK.Cost is what you spend , value is what you get.
cell # 413-841-6726
Pricing
Those prices are per section. But still nice to see somebody making them from scratch. If you could get a big enough order together and wait for them then container freight would not be to much $.0 -
doh!
I was in a rush .. I didn't hunt around to see if it was per section or not .. I actually added one to "my cart" .. it really should complain when you add just 1 section .. thanks steve for pointing this out.
Here's 1 "decorated" one I found on CL (I asked for better pics) .. it's a MONSTER: http://is.gd/jfZL3
and another not so decorated .. but also BIG: http://is.gd/jfZAU
I'm actually trying to hunt one down for my Barber right now ... while sitting for my haircut I noticed that his 1-pipe valve bonnet could be repacked and tightened as it was hissing and spurting steam so I told him I'd do it for him .. as we got talking .. he was complaining about the "steel pipe with aluminum fins on it" with a gorton tapped into a pipe-cap "radiator" he has in his shop .. I told him I'd help him find a suitable Cast Iron Rad.1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0 -
this too
http://www.victorianfires.co.uk/jig_radiators/index.html
actually, the prices are reasonable if you've ever got a sandblasting quote.
the UK is the only real outlet for cool (new) victorian era stuff, ie radiators, doors, mantles etc.
Hey JP, now all you need is a white utility body truck w/ pipe racks and you're good to go. call it Dr. 'Steam' Freeley.There was an error rendering this rich post.
