I can't find the EDR values anywhere
I'm sizing up a new boiler for a 10 unit prewar building in NYC. They have these old recessed convectors that I can't find EDR values for. I even looked in Dan's book. Here's a photo of each end of a convector. This one was 8" wide, 6" deep by 60" long. The others in the building are the same style, but only 2" high, 6" deep and varying lengths, I'm including a photo of one of those too.
Right now the building has a boiler I believe might be oversized but I need to figure out these EDRs first. In the meantime I have been using values for Sterling convectors..
Thanks guys...
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    cabinet dimensions affect EDR on a convector
    We will also need the dimensions of the cabinet, not just the fin tube element.
    Need to know the overall width, depth, and height of the convector unit.  Then comparing to the nearest should enable some of the pros on here to come up with a fairly accurate number.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Steve Fontas
    Steve Fontas Member Posts: 26
    edited December 2010
    That would be great
    But I didn't think You guys would give me EDRs for 25 different units. I was kind of looking for a place t find them myself. In any case, they are fully recessed, 24" enclosures. Here's a spreadsheet.
  • Dave in QCA
    Looks like Governale Bros. International Convectors
    Lookin your copy of EDR, page 215-217.  Look especially at the image on pg 216, sure looks like the element in your first 2 images.  They were manufactured in New York, so makes a lot of sense that may be what you have.
    I don't know whether your 3rd image relates to pg 217, or whether it may be a replacement element.
    Hope this helps.
  • Steve Fontas
    Sweet
    Thanks Dave. I'll look. How did I miss that?
  • Steve Fontas
    It might be them
    Guess, I'll just have to go with those. Thanks again, Dave.
