Safe water level????
Roebling
Member Posts: 7
What is the safe water level reading for a oil boiler? I have a glass tube that shows the water level bouncing around midway up the tube. Is this safe?
midway is fine...
low water cut off's usually trip at less than 1/4 way. if you don't see any water, I would be VERY worried.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
safe water level
ok, my roommate was saying that you need to be concerned about the water level in the gauge when the boiler is not burning. And when it is burning, it is normal to see it dip under halfway in the gauge because the water is up in the system as steam, is this right?
Such an amateur question I know, but I need to understand this critical stuff. Thanks!!0 -
Design Water Level
Hi - As JPF mentioned, having the water halfway up the sight glass tube when the boiler isn't running, is "in the ball park". You can find the measurement (up from the boiler's base) for the designed waterline in the Boiler's I&O manual (Installation & Operation). If you don't have the manual, let us know the make and model numbers of your boiler (They're on the manufacturer's plate attached to the boiler) and we may be able to find you a copy.
You might also be interested in getting a very good book on steam heating available on this site. It's called "We Got Steam Heat!"
http://www.heatinghelp.com/products/Books/5/61/We-Got-Steam-Heat-A-Homeowners-Guide-to-Peaceful-Coexistence
It's written for the homeowner and is easy, humorous reading and after a few nights of reading you'll be light years ahead in your knowledge about residential steam heating and it's operation. This book has actually saved me at least 100 times valve since I got it.
- Rod0 -
safe water level
Thank you guys for taking the time to give good answers, much appreciated! Rod, I am one step ahead as I actually ordered all 3 books in the "steaming good deal", so I am eagerly anticipating their arrival. When I get home tonight, I will look up the make and model number of my OLD boiler, which appears to be from the 70s. That would be excellent if anyone has the manual.
I am a new homeowner in a 100 yr old house, so this website seams to be just what I need!0
