HeatTech Clothing Anyone?
D107
Member Posts: 1,945
This is being advertised on NYC subway billboards. I wouldn't be surprised if Dan's already had this in his newsletter. Has anyone tried this product?
"When HEATTECH absorbs body moisture, the movement of tiny droplets actually generates heat to keep you warm."
"Air pockets between the fibers retain both body warmth and the warmth generated by HEATTECH's moisture absorption.
<a href="http://www.uniqlo.com/jp/global/L3/us/men.html">http://www.uniqlo.com/jp/global/L3/us/men.html</a>
wearable steam heating system?
ah the inventive mind of the advertising copywriter at work!!--nbc0 -
I'm planning on buying one of their jackets and adding a Gorton #2 under each arm for when I really work up a sweat.0 -
Already got it
Mine is a jump suit like the one Elvis had. There's a T&P at the bottom of the zipper. I kid you not.0
- 120 Geothermal
