Help with age of furnace
JRider
JRider Member Posts: 3
Tried this post in the radiant section without any luck...thought I would try this section as well. I'm trying to figure out the age of a General Automatic gas furnace/ radiant system. The model number is LG-6P and the serial number is 77564-509. Thanks for any help!
Jason
    Steamhead Member Posts: 18,205
    General Automatic
    was very active in the 1950s but faded out toward the end of the 1960s I believe. So if your home dates to that era it's probably original.
    G.A. was based in Baltimore- are you located in this area?
    Consulting
