Humidification in space pak vs stand alone
Tdlsdc
Member Posts: 4
I've got a unico space pak type ac unit and air handler in my insulated attic in Chicago. Does anyone have a preference for a steam unit in that air handler vs a stand alone through the wall stream unit? Any issues w mold in the space pak high velocity tubing?
Steam humidifier
The TruSteam humidifier that Honeywell makes can be mounted remotely, and connected to the supply trunk. The hose is insulated, and the unit can be up to 20 feet away. It reqires a drain, water supply and an elecric hookup that varies by unit capacity. These are available from your heating contractor, and are not sold at retail outlets as far as I know. I hope this helps.0
- 120 Geothermal
